Author Topic: Pillar Post Trim  (Read 1566 times)
Pillar Post Trim
« on: January 18, 2011, 11:00:56 PM »
Are the interior pillar post plastic trim pieces the same for all models ?  Are the Trim part numbers C9ZB 6503599 Left and 6503598 Right correct for the coupe and the fastback  6303599 & 6303598 ?  Thanks,  Brian
Offline cobrajetchris
Re: Pillar Post Trim
« Reply #1 on: January 19, 2011, 09:39:44 AM »
The trim pillar post are different between a coupe and fastback. The best way I have found to tell the difference is the number on the back, which I believe is a engineering # vs. a part # will have 63 in it as that is the fastback body code and 65 is the body code for the coupe model.
« Last Edit: January 19, 2011, 08:06:15 PM by J_Speegle »
CHRIS KNOBBE
« Reply #2 on: January 19, 2011, 02:38:24 PM »
Well duh.  Thanks for the ' nose on my face ' explanation.  Can't believe that never occured to me.  Thanks, Brain
Offline Carl
« Reply #3 on: January 20, 2011, 09:47:00 PM »
And the convertible posts are a third variation still, because of the top mounts for the convertible style header pieces.
  Carl
