Author Topic: Inner Fender, “splash shield” staples for rubber trim tree  (Read 2062 times)
Offline Craners
« on: September 12, 2020, 12:55:24 PM »
I’m currently restoring the inner fender splash shields...media blast and repaint.  Is there a source for the original staple that fastens  the rubber edge trim to the sheet metal?
I’m reusing they original rubber trim, but I hesitate to reuse the staples.
Keeping the original staple profile is required so the original rubber can be reapplied in the original hole pattern.
Thank you.
Fran
Re: Inner Fender, “splash shield” staples for rubber trim tree
« Reply #1 on: September 12, 2020, 01:52:34 PM »
Thank you.
Fran
There are reproduction ones sold. NPD is one source I believe. I have never compared them to see how close they were to original. I haven't had the occasion do do any recently(thank the stars) but I and many others just make their own.
« Last Edit: September 12, 2020, 06:46:48 PM by Bob Gaines »
« Reply #2 on: September 12, 2020, 01:53:39 PM »
Welcome to the forum.
I made my own from 0.047in dia steel wire. I cut the pieces to length, then bent them using a home made fixture in an arbor press. Installing was an all day plus task using the existing holes on the shields and new rubber. Good luck.
I put down the wire diameter as 0.032inch. The diameter of the replacement staples I've ordered were 0.062inch. I think that was the size Ford used for replacements and the aftermarket "copied" what Ford did. It's wrong.
One more point, I measured the staples on a 66 San Jose car. Measure yours. Also check the "form factor" of the staple, round or a rectangle profile. The rectangular ones may have a diagonal slant to make a point for penetration.
« Last Edit: September 12, 2020, 02:04:14 PM by jwc66k »
« Reply #3 on: September 12, 2020, 05:34:21 PM »
I make my own from .042" stainless steel safety wire. I don't care for the ones that come in the kits.
Thank you.
Fran
« Reply #4 on: September 12, 2020, 05:45:17 PM »
First welcome to the site. Hope you find the information and support helpful in your restoration project(s)
Here are some past threads on related to the subject. Almost always a great place to state looking
I like others have always made my own
http://www.concoursmustang.com/forum/index.php?topic=2498.msg75344#msg75344
http://www.concoursmustang.com/forum/index.php?topic=13782.msg91245#msg91245
http://www.concoursmustang.com/forum/index.php?topic=19406.msg122693#msg122693
