Author Topic: Vacuum advance - S Code  (Read 814 times)
Offline rocnhrse
« on: September 09, 2020, 09:40:34 AM »
The rubber hose that  comes  off the vacuum advance, where does  it  attach to, to get vacuum, I am having trouble finding a  picture,
« Last Edit: September 09, 2020, 02:45:14 PM by J_Speegle »
67 mustang  GTA  S code fastback  San Jose  April 67
Re: Vacuum advance
« Reply #1 on: September 09, 2020, 11:29:28 AM »
Try the 67 shop manual.
Offline 196667Bob
Re: Vacuum advance
« Reply #2 on: September 09, 2020, 01:16:51 PM »
See attached pictures. Don't pay any attention to the insulated choke tube ; it is just laying there.
Hope this helps. Note that this is on a 289 2 bbl.
Bob
MCA 04909
Re: Vacuum advance
« Reply #3 on: September 09, 2020, 01:21:23 PM »
I looked at the shop manual - general engine area, 390 engine area, and ignition (distributor) area but did not see anything.
I also looked at the vacuum manual but that does not cover the engine advance system.
Keep in mind that Bob's picture of the 289-2V is generally good, but the 390-4V will not be exact.
Also if you have the temperature based vacuum switch that adds to the complexity.
Can you confirm the engine that you are asking about, and let us know if you have the temperature based vacuum switch (aka tree) or not?
Offline rocnhrse
Re: Vacuum advance
« Reply #4 on: September 09, 2020, 02:19:06 PM »
The engine is a 390 in a 67 gta,thermactor car,I don't  have the tree type vacuum  fitting, I thought it was going to be at the rear at the bottom of carburetor which is a Holley 4150  C70F 9510 -D
Offline rocnhrse
Re: Vacuum advance
« Reply #5 on: September 09, 2020, 02:39:14 PM »
I have a fitting directly behind  distributor  with  2 barbs on it one goes to the anti backfire valve, could the other  barb be for the vacuum advance
Re: Vacuum advance - S Code
« Reply #6 on: September 09, 2020, 02:46:41 PM »
Add the "S code" to the title since it makes a difference in this setting and question
Offline 196667Bob
« Reply #7 on: September 09, 2020, 02:53:09 PM »
One of the attached should cover your situation.
Bob
MCA 04909
Offline rocnhrse
« Reply #8 on: September 09, 2020, 03:07:38 PM »
Yes that's  the schematic I am looking  for,thanks for your help,I looked again in shop manual, and on page 10-84,fig2,it shows a port on the metering block for vacuum  line connector,next time I will  look harder
« Reply #9 on: September 09, 2020, 03:10:59 PM »
Bob
Looks like the middle one. Others don't apply
Picture for one of the applications (Manual - thermactor - automatic or combination) makes a difference
And for the other
« Last Edit: September 09, 2020, 04:59:58 PM by J_Speegle »
« Reply #10 on: September 09, 2020, 03:37:20 PM »
Those drawings are from the "67 Ford Products Engine Assembly Manual". I recommend you get a full set of assembly manuals for your car.
« Reply #11 on: September 09, 2020, 04:23:24 PM »
You got it. I think that it is called ported vacuum, on a Ford numbered Holley 4150.
« Reply #12 on: September 09, 2020, 05:00:20 PM »
.... I think that it is called ported vacuum, on a Ford numbered Holley 4150.
+1
