Author Topic: What’s this foam tube/sleeve?  (Read 1991 times)
Re: What’s this foam tube/sleeve?
« Reply #15 on: September 06, 2020, 03:53:15 PM »
Yes but was it used/installed on the 65-66 and 69-70 cars ?
A sleeve was not used on 65-66 or 71-73
« Reply #16 on: September 06, 2020, 05:25:32 PM »
Though I would post a few pictures of some different versions/providers
9R1315xx Looks more of the foam type - Thicker walls
9F2169xx Given the fit may be one of the triangle shaped versions I mentioned earlier. Harder rubber look with ID ribs in the product
9F01F1588xx Another from Dearborn. Again looks to be thinner and harder rubber
Poor shot of the small tack weld/bead Ed referred to in his last response
Has to be a few out in the garage or some where just not sure where they might be
Since they were mentioned guess its ok to add a picture of the inner front bumper arm bumper from 9F1413xx
« Last Edit: September 06, 2020, 05:28:08 PM by J_Speegle »
« Reply #17 on: September 06, 2020, 08:02:44 PM »
Got that resolved in short order. Thank you.  Brian
Offline DougDyar
« Reply #18 on: September 09, 2020, 11:03:41 AM »
So for a '69-'70, does this insulator belong on the 17766/67 arm or on the 17754/55 tubular bracket? Seems like two completely different items.
The drawings posted above show both? Which is correct?
0F02G203277
Offline DougDyar
« Reply #19 on: September 09, 2020, 11:11:52 AM »
Ok, so Jeff's photos explain it. We were typing at the same time...
Now I need a pair of each as mine are missing...
0F02G203277
« Reply #20 on: September 09, 2020, 02:44:39 PM »
Not that it makes a bid difference IMO since we know what part it is visually but for the "numbers people",
17754/55 shown in reply #6  Reply #10 appears to be a 67-7 illustration
