Author Topic: What’s this foam tube/sleeve?  (Read 2216 times)
Offline 7Lscjracer
« on: September 01, 2020, 03:50:29 PM »
Organizing parts of my car and can’t recall with certainty what it is
PS hose protector perhaps?
Bought May '81, sold Sept '20
Offline Coralsnake
Re: What’s this foam tube/sleeve?
« Reply #1 on: September 01, 2020, 04:50:26 PM »
Rubber hose, split length wise?
If so, outer Bumper arm
« Reply #2 on: September 01, 2020, 06:48:46 PM »
If spongy foam then most likely a portion of a PS hose protector used on 69/70. There is more to it typically. Daniel carpenter makes it and NPD sells it .https://www.npdlink.com/product/sleeve-power-steering-hose-protector/147048
« Last Edit: September 01, 2020, 06:53:50 PM by Bob Gaines »
Offline 7Lscjracer
« Reply #3 on: September 01, 2020, 07:09:27 PM »
Thanks for your insights guys.
I have the split rubber hoses in place on the bumper arms so it's not one of those.
Spongey material anyway, and it could have been cut by someone, but if that happened it's odd it wasn't gotten rid of entirely instead of bothering to cut it.
« Reply #4 on: September 01, 2020, 10:23:40 PM »
Correct name, part number or supplier of the " split rubber hoses in place on the bumper arms " ?  New to me and don't have them on my car.  Thanks, Brian
« Reply #5 on: September 02, 2020, 12:26:06 AM »
It is referred to as the front bumper arm insulator .C7ZB17B947-B is the 67/68 .I didn't look up other years numbers. Ford is the supplier. ;) You can find illustrations in the Body assemblyline manual on the page that shows the bumper and attaching parts for the year in question. The material  is similar to a heater hose but different texture ,thickness and diameter. It is closer to the appearance if not exact as the hose used on the fastback quarter box drain hose 65-68.
« Reply #6 on: September 02, 2020, 08:07:35 AM »
As Bob stated, the Ford nomenclature is "insulator - front bumper arm"
By the time that the 1975 "final" version of the 1965-1972 MPC was published, there were no 17B947 parts serviced for any year Mustang.
I found the diagram where the 67-68 insulator is shown, but for the 69-70 (see P-6664 attached) this part is not called out.
« Last Edit: September 02, 2020, 08:10:58 AM by 67gta289 »
« Reply #7 on: September 02, 2020, 11:55:06 AM »
Thank you for the info and very clear explanation/description.  Never seen these an any car and not on my 65 or 69.  Brian
Offline 7Lscjracer
« Reply #8 on: September 04, 2020, 11:48:03 PM »
3-1/2” long
« Reply #9 on: September 05, 2020, 12:44:20 AM »
Have seen a couple of different shapes and types of material used on unrestored cars. Might be multiple suppliers and plant differences again.
Like heater hoses the number and placement of ribs may identify supplier
Some seem more rubber like and other more foam like.
Round and triangle shaped ones also. Will find pictures and post
« Reply #10 on: September 05, 2020, 12:02:24 PM »
The ' insulators ' are in this illustration taken from the 69 Shop Manual.
« Reply #11 on: September 06, 2020, 10:36:26 AM »
These rubbers are often missing in a restoration or in the wrong position as there is a weld spot about 4'' from bumper end of the rod and these rubbers are supposed to stay between the weld and end of rod to protect valance panel from rubbing or hitting the rod and  chipping the paint off the valance panel.
« Reply #12 on: September 06, 2020, 01:11:24 PM »
NPD sells the insulator kit but for 67-68 Mustang and Cougar only ?  https://www.npdlink.com/product/insulator-kit-front-bumper-bracket-4/102992
« Reply #13 on: September 06, 2020, 01:24:24 PM »
I don't think that keeps someone from using it on other years if they choose to. The insulator hose doesn't look like the original hose unfortunately.
« Reply #14 on: September 06, 2020, 03:07:06 PM »
Yes but was it used/installed on the 65-66 and 69-70 cars ?
