Author Topic: Does anyone make a good reproduction smog hose set for 428CJ?  (Read 1255 times)
« on: September 01, 2020, 11:05:22 AM »
The lettering / numbers just fall off the current crop of repros. Originals had the lettering deeply embossed and painted - those are much more sturdy. Is there any solution to this problem?
Re: Does anyone make a good reproduction smog hose set for 428CJ?
« Reply #1 on: September 01, 2020, 03:05:01 PM »
The set up for the original process is too expensive for the small runs I have heard. I wish I had some positive insight on a alternative other then be careful not to rub on the ink when cleaning . Test any cleaning product on a inconspicuous area before use. The ink does not stand up to a aggressive cleaners well at all.
« Reply #2 on: September 01, 2020, 07:20:25 PM »
I have not cleaned the hose at all - nor touched it. The lettering / number are just falling off a hose that is about 18 months old. Weird thing - they stay on the short S - bent hose and the short hose in front.
« Reply #3 on: September 01, 2020, 07:39:14 PM »
It sounds like the surface was prepped properly before they applied the ink. Typically the repro hoses do not have the lettering/numbers falling off. They will rub off easily but I haven't heard of your problem before.
