Author Topic: 67 San Jose Battery Reinforcement - Running Change  (Read 647 times)
Offline V8_bloke_28
« on: August 29, 2020, 10:53:40 PM »
Gday,
I have a 26 June 1967 s code Fastback built in SJ and need help with the battery reinforcement that is spot welded to the apron.
I purchased a replacement apron for a 67 and the reinforcement looks different/skinnier.
Question is, is this one of those running changes that were made between early and late 67?
Does this mean I need to get the 68 style apron?
Cheers
« Last Edit: August 31, 2020, 01:40:17 AM by J_Speegle »
Re: 67 San Jose Battery Reinforcement - Running Change
« Reply #1 on: August 30, 2020, 12:21:13 AM »
Mansfield Mustang sells this one: http://mansfieldmustang.com/06-86.jpg
Edited because my I Phone spell check is retarded.
« Last Edit: August 31, 2020, 01:40:06 AM by J_Speegle »
« Reply #2 on: August 30, 2020, 05:53:17 PM »
Haven't noticed the detail before but can see the difference between what you took off and the one on the donor panel as well as the reproduction.
Though it may be unconnected does your car have the hole for the extra upper battery support bracket?
http://www.concoursmustang.com/forum/index.php?topic=20719.msg130479#msg130479
In a quick look through my pictures I see other 67 examples with the wide underside brace like your original one as they are wide enough to been seen as the are almost wider than the bottom of the inner fender panel in that area once welded in place. Will look further and report back with  what I find. Plenty of 67 owners who hopefully will offer additional insight
« Last Edit: August 31, 2020, 01:39:59 AM by J_Speegle »
Offline bazza
« Last Edit: August 31, 2020, 01:39:52 AM by J_Speegle »
67 Dearborn S code coupe Built 8/17/67
« Reply #4 on: August 31, 2020, 01:41:25 AM »
Changed titles on both threads so they don't get confused with one another. Sorted out a bunch of pictures just have to record the VIN's and see with that can tell us
