Author Topic: 1966mustang water pump question  (Read 901 times)
Offline MomsMustang66
« on: August 13, 2020, 10:47:17 PM »
I have a 1966 mustang with an A code 289 engine. The front timing cover is aluminum. The water pump is cast iron. Is this the correct pump? I have seen comments elsewhere that aluminium pumps went with aluminum front covers and cast iron pumps went with cast iron timing covers.
Re: 1966mustang water pump question
« Reply #1 on: August 13, 2020, 11:42:14 PM »
SB timing covers are typically aluminum up to a least the mid 70's. I don't pay much attention to those details after the 60's. The water pump on the SB changed to cast iron in late 65 production . Your 66 would have a C6OE marked cast iron water pump from the factory.
« Last Edit: August 14, 2020, 12:05:42 AM by Bob Gaines »
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: August 13, 2020, 11:55:55 PM »
to correct BOBS post a little.  a 66 V8 Mustang would have a cast iron water pump with the visible casting code C60E-A
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #3 on: August 14, 2020, 12:06:27 AM »
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
Thanks for bringing the typo to my attention . ;) Fixed.
« Reply #4 on: August 14, 2020, 09:00:08 AM »
I have a 1966 mustang with an A code 289 engine. The front timing cover is aluminum. The water pump is cast iron. Is this the correct pump? I have seen comments elsewhere that aluminum pumps went with aluminum front covers and cast iron pumps went with cast iron timing covers.
there are no cast iron timing covers in '66 or any other year. your source is incorrect.
« Reply #5 on: August 14, 2020, 11:02:57 AM »
Thanks everyone for your replies. Present setup is good then.
« Reply #6 on: August 14, 2020, 05:49:40 PM »
Is this for concours?
There are a great many visible differences on timing covers. Ribs, no ribs, etc.
Post a pic.
« Reply #7 on: August 15, 2020, 12:07:21 AM »
Post a pic.
For the late 65, all of 66 and early 67 there were ribs. Later 67 had no ribs. Per Mannel (Appendix E, page E3, note 6)
« Reply #8 on: August 15, 2020, 05:20:15 PM »
Yes I agree. Good reference.
I was suggesting the OP go look so the version he has can be verified as correct or needing replacement.
