Author Topic: 1967 Ford Distributor casting numbers  (Read 658 times)
Offline Z67Fback
« on: August 10, 2020, 09:42:18 PM »
A question concerning the multitude of different distributors casting numbers for small blocks in 67. I see they had different numbers depending on 2v/ 4v carbs  or what type of transmission. What were the differences in the distributor? The amount of mechanical advance? Were there different type of vacuum advance also? How much performance difference if the distributor was mismatched with different carb or tranny type?
Thanks in advance.
1967 Fastback, C Code, 4 Sp MT, 7T02C226959 Build Date 4/11/67. Built in Metuchen, NJ
Re: 1967 Ford Distributor casting numbers
« Reply #1 on: August 11, 2020, 12:01:41 AM »
The distributor bodies for any given year were the same for each engine family. The numbers stamped on the side represent the entire finished product. Advance spring rate for the centrifugal advance were different from some models to other models. The vacuum advance came in either dual or single versions, as well as six cylinder or V8. The vacuum advance units could be tuned with a limiting spacer and / or washers inside, along with various different springs.
The good news is that a distributor can be tuned to make it work properly so long as it is made for that engine family. The numbers on the outside will tell someone a different story particularly if they are expecting to find a concours correct part.
Thanks in advance.
« Reply #2 on: August 11, 2020, 12:15:58 AM »
............... What were the differences in the distributor? The amount of mechanical advance? Were there different type of vacuum advance also? How much performance difference if the distributor was mismatched with different carb or tranny type?
There are also differences between non-Thermactor and Thermactor calibrated distributors
Yes all of those. Since it appears that your likely focusing on 289 applications given your signature there were two different bodies ( one for vacuum advance and one without) All had mechanical advance - some also vacuum also. There were difference vacuum advance units (calibrated for the application) You will likely not notice any performance differences between the correct for your car and one made/calibrated for a different one. Difference may come into play with increase emissions and drivability  and of course only one will be correct for your car
