Author Topic: trunk mat for Feb/68 Shelby convertible  (Read 3467 times)
Offline kwemj 67
« on: August 10, 2020, 07:55:05 PM »
Used the search feature on website to answer my question on what style of trunk mat should be in this Feb/68 Shelby convertible, not Burtex? Also did the mat go under the trunk divider board or just trimmed up to it? Just want to confirm this.  Thanks.
7R03S157303 GTA
Re: trunk mat for Feb/68 Shelby convertible
« Reply #1 on: August 11, 2020, 12:25:53 AM »
Not that we can't add more to the thread but did you find the Running Change thread for 68 NJ trunk mats when you searched the site?
http://www.concoursmustang.com/forum/index.php?topic=22472.msg140974#msg140974
Don't know that I've got any new ones since May when these were posted, but will check
Offline Coralsnake
« Reply #2 on: August 11, 2020, 09:26:02 AM »
The were a couple different materials used. The speckled burtex is correct. A felt style mat would probably also be acceptable.
I have seen the mats screwed down, but if I recall correctly that is more common on the 4spd KRs.
« Reply #3 on: August 11, 2020, 10:27:47 AM »
On a convertible, the mat was typically under the divider board, screwed down.
Offline kwemj 67
« Reply #4 on: August 11, 2020, 12:58:12 PM »
This car is 169XX-1424 and was stamped on Feb 02/68, the earlier cars were still Plaid and Felt and then switched to Speckle on later ones? That picture of the Highland green 1795XX is fairly close in serial number and it is Plaid. Ok on the mat getting screwed down from the divider board.
7R03S157303 GTA
Offline kwemj 67
« Reply #5 on: August 11, 2020, 02:58:53 PM »
Also the bottom of the divider board, have seen the lip with the screws both ways, screws showing in trunk area and some with screws in the top well area. My 67 GTA has them in the top well area.
7R03S157303 GTA
« Reply #6 on: August 11, 2020, 05:23:03 PM »
Also the bottom of the divider board, have seen the lip with the screws both ways, screws showing in trunk area and some with screws in the top well area. ..
At the same plant and year?  Guessing your only comparing unrestored cars ;)
With you other car your comparing different year and plant  and in turn different plant lay out and workers
Offline kwemj 67
« Reply #7 on: August 11, 2020, 07:15:55 PM »
Your right Jeff, my car 67 and San Jose plant. So for the Shelby they should be showing inside the trunk area. Thoughts on mat?
7R03S157303 GTA
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #8 on: August 16, 2020, 04:44:20 AM »
May built KR convert I am working on has the original felt style trunk mat.
MCA#31064
Offline kwemj 67
« Reply #9 on: August 16, 2020, 11:09:54 AM »
I don’t think anyone reproduces the felt style mat that I have found.
7R03S157303 GTA
Offline TLea
« Reply #10 on: September 25, 2020, 10:38:49 AM »
First choice on feb vert would be speckled butted. Felt occasionally used but tends to be on earlier fastbacks and late verts. Majority of boards screwed over mats would be later 4 speeds
« Reply #11 on: September 25, 2020, 01:19:50 PM »
Because of the staggered shock bracing across trunk floor being different?
Offline TLea
« Reply #12 on: September 29, 2020, 07:02:33 AM »
Yes.
