Author Topic: 67 Shelby taillight bezels  (Read 4562 times)
Offline daveb9
« on: August 06, 2020, 02:26:17 PM »
  I am looking for new taillight bezels for my 67 GT500. It is a 1st week of February car and was wondering if it would have the bezels with studs or screws? Not sure when the change was made. Any help is greatly appreciated.
Dave
Re: 67 Shelby taillight bezels
« Reply #1 on: August 06, 2020, 02:28:49 PM »
Dave
What Shelby vin is the car?Do you have the flat tail panel or the contoured?
Offline daveb9
« Reply #2 on: August 06, 2020, 04:37:58 PM »
67400F2A01043. I will find out about the panel.
« Reply #3 on: August 06, 2020, 05:50:39 PM »
For this detail (Ford verses Shelby processes) you car was completed at the end of March 1967
Offline daveb9
« Reply #4 on: August 06, 2020, 08:04:02 PM »
Panel is flat.
« Reply #5 on: August 06, 2020, 10:48:02 PM »
Panel is flat.
That would be typical and would be inline with other cars produced about the same time as yours by observation. You should be looking for the tail light bezel with studs. It seems like the change in tail light bezels coincides with the change in tail panel flat to contoured. The trunk side light boxes were also changed at that time.
« Reply #6 on: August 07, 2020, 01:49:37 AM »
Bob, my tail lamp boxes are closed in on the ends. I would assume that means there are three different boxes. two for flat panel cars and one for contoured panels?
Why don't you post a picture of what your box ends look like.
Offline daveb9
« Reply #7 on: August 07, 2020, 11:26:22 AM »
Thanks Bob. I talked with Chris B. who is doing the car, and he felt the stud type also. We just wanted to ask here to make sure. Great to have this resource to come to for info.
Dave
« Reply #8 on: August 20, 2021, 06:35:10 PM »
Might as well tag onto this post.
After much fun (!@#$%^&) drilling and taping the broken studs on my car I have to ask what the finish is on the front. Pic here to show part number and that I cleaned off the back under 25 psi glass ball while the front was taped off.
The SAAC forum says stuff like shiny but not too shiny. This is like saying semi-gloss (I have come to hate that non-specific term)!
Any help on where I end up? Is this like 1500 wet/dry shiny?
Also, how many surface imperfections are allowed? This is not the finest aluminum casting I've seen so are the pinholes in mine from corrosion or simple porosity? There isn't any on the main overall surface (like you see on an aluminum framed window).
« Last Edit: August 20, 2021, 06:37:17 PM by Bossbill »
« Reply #9 on: August 20, 2021, 07:29:52 PM »
Shiny like 400 shiny.  From the NOS and originals that I have seen the finish is like 400 grit shiny. Many over restore them because it is easy to make them look shiner.600 is pushing it if you want the original look. The mirror finish are the ones on the one extreme. Dull like the way the repros typically come are on the other end. I have seen porosity before.At least that is my opinion . Others may have different.
« Last Edit: August 20, 2021, 07:32:38 PM by Bob Gaines »
« Reply #10 on: August 20, 2021, 07:47:44 PM »
Thanks a bunch, Bob.
That's not very shiny ...
Offline S412gofast
« Reply #11 on: August 21, 2021, 12:02:27 PM »
this was recently posted in Parts for Sale
https://www.concoursmustang.com/forum/index.php?topic=23861.0
1967 GT350 01341, FORD Build: 2/28/67 ; SAI Build 3/28/67
1966 GT 2+2, 4spd, PS, tinted windows, Raven Black w/Black Pony interior; FORD Build: 10/11/65
1986 SVO, Oxford White w/Leather interior
1987 Saleen #132 Dark Gray Metallic
« Reply #12 on: August 21, 2021, 12:22:10 PM »
FYI those may be genuine lens but the trim rings are repros.
« Reply #13 on: August 21, 2021, 01:42:56 PM »
Looking through a few backend shots I found the white Shelby that was judged at the Minnesota MCA show a few years ago.
After looking at all the other very shiny to mirror shiny versions this one appears to represent low gloss 400 (approx).
I wonder how to get there. It almost looks lightly media blasted.
« Reply #14 on: August 21, 2021, 02:23:37 PM »
If you are starting with ones that are more polished then you may have to lightly bead blast (just enough to dull) them and start from the ground up . In that case maybe start with 250 and work your way up . You want a gradual finer grade sand paper so as to get all of the heavier scratches out before moving on to the next finer.
