Looks like I had the correct clutch lever all along. Apparently this is a known issue for the BB cars. Got this response from the RAM rep:
Antonio - those are the correct bolts, but in the BB apps the lever clearance is tighter than most SB apps. Two options, or a combo, you can try first removing the star washers under the bolts and see if this gives you adequate clearance, if not we have a shaved bolt we can send you to install.
If you choose to do this, make sure you hold up on the lever when you pull the bolt out, as there are shims underneath between the cover and the yoke that holds the lever in place. A drop of Loctite on the bolts will retain them fine.
If you would like the shorter bolts, send me your shipping info and I'll have them sent out.
Thanks everyone for your help. I really appreciate your time/input.
v/r
Tony
