Author Topic: 1967 Brake Line From "Rear Proportioning Valve" to Bracket of Rear Flex Line  (Read 1182 times)
Offline kkupec02
I have looked everywhere for this brake line shown as tube 2B113 in the attachment. I have checked CJ's, Virginia Mustang, Rock Auto, called NPD, Tony Branda all to no avail. Has anyone bought a pre-bent line for this 3" or so application or must one be made from scratch? Thanks
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
I found them in two places; (1) Ford NOS in box along with the 2B091 proportioning valve, and (2) in a complete aftermarket brake line kit from any number of vendors.
I don't recall seeing it available by itself.  I'll take a look later to see if I have any extras.
Offline kkupec02
I bought brake line kits from NPD and it wasn't included. I called NPD and they said they do not supply it in any form, with or without a kit. I could make one, just easier to buy if available.
My extras are used, not “Shelby” worthy :) :)
Very common fittings that can be purchased at a good parts store, very easy with a double flaring tool to make it but I do say, I live in the rust belt of Ohio and brake lines are a part of doing business for me.
Sorry to hear you damaged the one on your car. Believe your going to be making one of getting someone else to make you one
Offline kkupec02
I actually haven't even tried to remove the current one yet. But seeing how rusty it is, I know it will be of no value when I am done. I do have a double flare nut kit, so I guess I am going that route.
Offline kkupec02
Thanks all. I will call Classic Tube and In Line Tube tomorrow.
Offline kkupec02
I called Classic Tube today. They say NPD doesn't sell their whole car kit, just parts of it in smaller kits. Classic Tube has the small line in a full kit that they sell for $120, so I bought it. I was missing other lines as well anyway.
Offline kkupec02
Thanks all
Offline T-Bone68
Sounds like you already solved your problem, but just in case anyone else is looking for the same answer...
If you order the correct intermediate brake line, that little 90 deg piece usually comes zip tied to it.  Look for "2pc" in the description.  I just replaced my intermediate line and that short 90 deg bend from Fine Lines / SSTubes and it fit fine.  Part ZIN6704OM in my case.  I would bet Classic Tube does the same.
One caution if searching NPD, there is an item 2B092-1A that says proportioning valve... 67 Mustang... and sure looks right by the picture.  It ain't.  What shows up doesn't match the picture.  Dumb me should have known from the description it wasn't right, but was desperate enough to try.
