Author Topic: 1967 Ford Mustang Battery apron wiring harness holes  (Read 699 times)
Offline Z67Fback
« on: July 28, 2020, 08:00:50 AM »
Good morning
I noticed my starter relay harness is not secured with the push in clip to the battery apron. Does anyone have any pictures of how the harness is mounted and where the push in clip hole should be. My battery apron is a replacement panel. Thank you in advance for any and all info.
1967 Fastback, C Code, 4 Sp MT, 7T02C226959 Build Date 4/11/67. Built in Metuchen, NJ
Re: 1967 Ford Mustang Battery apron wiring harness holes
« Reply #1 on: July 28, 2020, 08:37:53 AM »
This is our 68 GT350 that was in a fire but the wire retainer holes are the same as 67
Offline Z67Fback
« Reply #2 on: July 28, 2020, 10:16:16 AM »
Thank you so much. Very sorry to hear about your car fire. Were you able to salvage your car? What was the cause?  Thank you again!
SCott
Offline 196667Bob
« Reply #3 on: July 28, 2020, 11:56:29 AM »
Attached is a picture of our 1967, January 31, 1967 Dearborn Convertible with Power Top, that clearly shows the clip by the Battery Tray.
Bob
MCA 04909
« Reply #4 on: July 28, 2020, 03:03:39 PM »
SCott
You are very welcome.
The fire was a couple of years ago and it almost as good as new with some help from my friends.
I had used a propane torch in the shop the night before and the valve malfunctioned. The car did not burn just got smoke damage everywhere.
Offline Z67Fback
« Reply #5 on: July 28, 2020, 10:06:53 PM »
Beautiful ride!  Thank you all for the assistance! Very grateful
« Reply #6 on: July 29, 2020, 05:31:39 PM »
Sorry a little late to the subject
Here is an example from a 7T23xxxx example
Plus since you asked about holes for the wire harness in that panel there is the one under (wire loom runs between the battery tray and inner fender panel) below the battery area as shown below. Round opaque retainer
