Author Topic: Help with wiring please!  (Read 862 times)
Offline Panther99
  • '70 Mach, '67 Fastback
« on: July 27, 2020, 02:32:14 PM »
Trying to finally finish up wiring on a gt w/fog lights and tach.  Can anyone tell me what the yellow w/black stripe and blue w/black stripe wires are that are part of the 12-pin instrument cluster harness?  Thank you in advance for your experience and insight.
Re: Help with wiring please!
« Reply #1 on: July 27, 2020, 02:40:29 PM »
what year please?? suggest you add your car's info to your signature. it will prevent being repeatedly asked what the info is for. and welcome to the board!
Offline Panther99
« Reply #2 on: July 27, 2020, 03:00:22 PM »
Apologies.  This is for a '67 fastback.  Thanks (now with an Atari technology level - will try to update my profile).
« Reply #3 on: July 27, 2020, 03:00:41 PM »
On 67, since this is area of forum posted:
Blue/Blk= optional clock power.
Yellow/blk = 1/2 of alt warning light. Other half black/blue.
Offline Panther99
« Reply #4 on: July 27, 2020, 05:06:09 PM »
This aligns with the diagram below, but as far as I can tell, these are for non-tach cars.  As you can see in the picture there are several deviations for a tach harness from the diagram, the yellow/black is in the 655 position and the blue/black is in the 654 position.  Unless I'm missing something really obvious.  Thanks.
« Reply #5 on: July 27, 2020, 05:20:47 PM »
Do not use diagrams from a non tach car to help confuse yourself, find the correct diagram for a tachometer car.
Service manuals do not have a schematic for the tach cars but I believe the Osborn Assembly Manual does but not near me at this moment.
« Last Edit: July 27, 2020, 05:25:59 PM by 67gtasanjose »
« Reply #6 on: July 27, 2020, 06:01:50 PM »
Rich, and what ever Panther 99 secret identity is,
The 67 Mustang Electrical Assembly Manual does not show a tachometer schematic, but it does show a where to install the factory tach in the ignition circuit under the dash (AM0018 page 54, E7-8617-1). (It's the same inline hookup as a 65/66 tach, between the ignition and the pink resistance wire.) I assume the standard instrument lights provide illumination as they are not described. Page 21 (E7-8145-2) lists 6 different cluster assemblies, 4 with tach (6K, 8K, 6K with Decor, 8K with Decor). The wiring is simple, where the wires hooks to up is subject to the "optional" clusters.
« Reply #7 on: July 27, 2020, 06:02:45 PM »
My comments apply to my signature car with tach and clock.
« Reply #8 on: July 27, 2020, 09:05:02 PM »
Ding Ding Ding!  We have a winner.Ford, in their infinite wisdom, never published any 67/68 tach-specific wiring diagrams.  I have reverse-engineered them, and Bossbill is correct.  The yellow/black and black/blue do go where the two ammeter lines were in the plug for the non-tach configuration.  Blue/Black is at the end; yellow/black next in line.
« Reply #9 on: July 27, 2020, 09:45:38 PM »
You can use the Cougar one from the shop manual.  Only requires a little reading between the lines.
« Reply #10 on: July 27, 2020, 10:45:06 PM »
If I remember right, one side of the alternator light goes to Ign 'on' (12V) and the other side to alternator (stator I think). If the alternator is not charging stator becomes a ground and the light is on. If the alternator is charging you get 12V on both side of the light and it goes out.
That's from memory.
Offline Panther99
« Reply #11 on: August 03, 2020, 05:56:07 PM »
Thanks to all for the help.  Hoping to finish up this week.  Nothing too secret - Panther (kid's school mascot) 99 (son's racing number).  If I've got something set to abnormally hide, please let me know - new user on this forum.  We've done a '70 mach for the older son's project and now redoing the '67 I've had since 1984 for the younger son's and getting down to the last of the wiring (I HOPE!!).
