Author Topic: Any success in duplicating SJ firewall mat dimpling?  (Read 574 times)
Offline TJinSA
« on: July 26, 2020, 01:24:09 AM »
Per my subject line, has anyone had even a modicum of success in duplication of the surface of the dimpled firewall mat?  What was your approach / technique?
Re: Any success in duplicating SJ firewall mat dimpling?
« Reply #1 on: July 26, 2020, 01:50:50 AM »
That would be quite an involved process, I'm not aware of anyone that has ever attempted it.
« Reply #2 on: July 26, 2020, 07:47:39 PM »
If you use the search there was an attempt by one of the members a few weeks back. Think they copied the idea from a shops Facebook post. Unfortunately they got the pattern incorrect :(  The process was to make a mold, pour a product into a repair panel, fill it and bond it to the firewall pad all at the same time it appeared. Might work (if the pattern was right) to patch or repair a small area that was fairly flat but to apply the pattern across a complete, full reproduction pad with all the formed areas while retaining the pattern appears to be a challenge. Might take three of four pads before you get the technique figured out
