Author Topic: Paint marks for C4ZA-M Dearborn leaf springs  (Read 2977 times)
Offline Dave Stribling
« on: January 12, 2011, 11:19:34 AM »
Need to know the paint marks for  Dearborn C4ZA-M springs 610# dated March 64.  I know its a driver but I can't help myself......
Dave
Re: Paint marks for C4ZA-M Dearborn leaf springs
« Reply #1 on: January 12, 2011, 11:37:50 AM »
What body style and did it have special handling package?
« Reply #2 on: January 12, 2011, 12:41:44 PM »
Pace car coupe. 260 V8 no special handling
« Reply #3 on: January 12, 2011, 07:45:25 PM »
Have the -M taken from a 66 car marked with 2 white marks
Interesting that those were one of the springs apparently installed on 6 cylinders in 66
« Reply #4 on: January 13, 2011, 09:24:48 AM »
Two white marks it is.  Thank you sir!
Offline JKWilson
« Reply #5 on: January 13, 2011, 07:33:03 PM »
Jeff I can confirm those were the same markings I found on my '66 6cyl Dearborn coupe!
Offline Twilight65
  • Gold Level Subscriber
« Reply #6 on: January 13, 2011, 08:50:03 PM »
My July 65 with 289 had the C4ZA - M springs with two white stripes.
Dave
Offline Pete Bush
« Reply #7 on: January 14, 2011, 06:52:58 AM »
My MPC indicates that the 610 lb. springs were used on 65 and 66 coupes; both 6 and 8 cylinders. Looks like it could have been an M or C, E, T code. I wonder if they were all marked with white paint?
Fastback's and convertibles used the 650 lb. springs: C4ZA - B, D, F, or N. Why four possible choices for each load rating?
« Reply #8 on: January 14, 2011, 01:40:33 PM »
My guess is that each of the springs were used during production (Each letter signified some change in the spring or there would be no reason to change the engineering number) but since the MPC is simply a list of replacement parts (rather than a list of what was used on the line) someone at Ford choose to lump these together and assign a replacement (good/close enough) service replacement for that group.
As far as all being marked with the same color - doubt it but time will tell as we collect more data from what they did on the line
Offline tomtri66
  • Bronze Level Subscriber
« Reply #9 on: March 01, 2013, 09:54:59 AM »
I also found 2 white stripes on my C4ZA-M springs.  They were found about 1-2 inches from the end of the 3rd leaf.  At first I thought I had found a white dot on the 4th leaf but that turned out to be false as there was more undercoating beneath it.  After further careful stripping of the undercoating the true white paint stripes revealed themselves.
« Last Edit: March 02, 2013, 12:48:27 AM by tomtri66 »
C/O    762
4        A20     6T07T194XXX
65A       Y        22
