Author Topic: A/T transmission speedometer gear  (Read 867 times)
Offline truetriplex
« on: July 19, 2020, 08:53:20 AM »
My rear axle was converted from a 3:00 to a 3:50. With the stock tires, what tooth/color gear should I put in the transmission to obtain correct speedometer reading?
Re: A/T transmission speedometer gear
« Reply #1 on: July 19, 2020, 11:01:02 AM »
Depends on whether you just want what Ford did or if you want accuracy. Are you using sized stock tires? Or something else?
To illustrate what works, I have 3.50 gears and F70-14 Firestone bias ply tires on my green GTE and the speedo is accurate. It has the black 20 tooth gear installed.
« Last Edit: July 19, 2020, 11:05:21 AM by RoyceP »
« Reply #2 on: July 19, 2020, 11:12:10 AM »
What model year, engine and transmission?  Info in MPC.  Perhaps shop manual also
Offline 1967FEGT
« Reply #3 on: July 19, 2020, 11:35:23 AM »
Because you likely can't get or won't the exact tire diameter used by Ford here's a simple calculator to determine your required driven gear.
https://www.moveras.com/Support/Tools/SpeedometerDriveGearCalculator.aspx
Offline Coralsnake
« Reply #4 on: July 19, 2020, 07:02:25 PM »
Ford used the #CODD-B part number CODD-17271-B / GOLD colored /18 tooth speedogear on a 428 CJ/ auto with 3.00 gears. As you stated you still have the E70x15 tires
That information comes directly from a factory build sheet.
« Last Edit: July 19, 2020, 07:08:02 PM by Coralsnake »
Offline Coralsnake
« Reply #5 on: July 19, 2020, 07:05:29 PM »
That changed to a # C4OA-A part number C4OZ-17271-A / Red / 21 tooth gear with a 3.50 axle, again from factory paperwork.
That would be a good place to start.
« Last Edit: July 19, 2020, 07:08:55 PM by Coralsnake »
