Author Topic: Original Radiator 66’ ?  (Read 969 times)
Offline woolshire
« on: July 15, 2020, 01:18:13 PM »
Hi,folks
Just thought you might like to see an original radiator, and I think cap, from my 66’ GT. It’s a two row and is still good! It came with my car but car now has a three-row original look rad.
I’m guessing not a ton of these around any longer. My car is non-restored but with one repaint in 2002. Original interior pony and 37k miles in it. I also have an 18 GT.
« Last Edit: July 19, 2020, 05:53:27 PM by J_Speegle »
Re: Original Radiator 66’
« Reply #1 on: July 15, 2020, 03:33:12 PM »
Where was the car built? And it might help others if you included the id and date from the side strap ;)
Offline ChrisV289
« Reply #2 on: July 15, 2020, 04:07:58 PM »
Fill portion appears to be in the middle and has a fomoco block debossed on top. I think that might be a later radiator.
2009 V6 Mustang Coupe
« Reply #3 on: July 15, 2020, 04:42:59 PM »
Kind of expect we will figure out things once we get additional information ;)
Offline woolshire
« Reply #4 on: July 16, 2020, 12:57:13 AM »
The fill is in the middle, and I assumed original...maybe not.
I’ll see if I can find a strap number. This radiator came with the car.
The car is NJ from end of October 65’. It has the buck tag and I found two build sheets. One under drivers seat and one around wiring behind instrument cluster.
What year(s) has the radiator fill in the middle? Thanks!
« Reply #5 on: July 16, 2020, 02:21:45 AM »
Not in the middle on 65 or 66 originally.
« Reply #6 on: July 16, 2020, 05:39:01 AM »
Common mistake is to assume that everything it original when you find a fairly original car.
The information from the strap should tell us what it came out of - The purpose of the question
Offline woolshire
Re: Original Radiator 66’ ?
« Reply #7 on: July 19, 2020, 03:25:15 PM »
Here’s a photo of tag. I still don’t know, as it appears several letters and number were repunched. Kinda looks like C3DE...not sure that makes sense. I think that would mean 1963 Falcon? But, they don’t have fill in center, either. Correct?
« Last Edit: July 19, 2020, 05:53:43 PM by J_Speegle »
« Reply #8 on: July 19, 2020, 06:02:09 PM »
Looks like we have confirmed (kind of knew this from the beginning) that it's originally from another car/application. You would need an earlier MPC or a cross reference manual (use to find them in yards as a reference book) to figure out what it came from
Though its a 65 manual radiator this is basically what should be in your car.
Offline Nightmist66gt
« Reply #9 on: July 23, 2020, 10:57:27 PM »
I just bought a rad that have the cap in the middle too, that is mustang parts number?
« Reply #10 on: July 23, 2020, 11:01:25 PM »
The side straps may be from a 65/66 Mustang but top tank is not. The side straps are soldered on and can get switched out easy enough.
