Author Topic: A/C vacuum control valve  (Read 1354 times)
Offline 1967FEGT
« on: July 14, 2020, 09:09:29 PM »
I have a 67 car with the large tank style vacuum reservoir. There is a round check valve that is just in and out. It is not like the three way tilt steering valve. Does anyone have the factory part number for the valve?
Re: A/C vacuum control valve
« Reply #1 on: July 14, 2020, 09:48:56 PM »
You will find that information in the library section under topic "ConcoursMustang.com Official 67 Mustang Article List" which has a copy of the "65-72 Ford Car Parts" (aka MPC). The MPC has your answer.
« Reply #2 on: July 15, 2020, 08:04:25 AM »
You are looking for a C6OZ-19A563-A check valve.
I've seen the same part used for tilt, A/C, and cars equipped with both.  I've never seen a 3-port check valve on a 67 Mustang.  I see 3 and 4-port valves on Cougars, Lincolns, T-Birds, Cyclones, etc.
« Reply #3 on: July 15, 2020, 11:52:27 AM »
It was used on '67 Cougars until mid year.
https://secure.cougarpartscatalog.com/67check.html?sessionthemeid=26
WCCC likely has them on a car in the yard.
Offline 1967FEGT
« Reply #4 on: July 17, 2020, 12:44:05 AM »
I found an NOS C5AZ-19A563-A1. Should that work for this application? I see it listed under the recommended in the MPC.
« Reply #5 on: July 17, 2020, 12:48:45 AM »
Are you wanting something that will work /function or something that will work AND looks the historical part?
Offline 1967FEGT
« Reply #6 on: July 17, 2020, 01:37:39 AM »
It looks like what I found in illustrations for the car. Is there some difference that isn't seen by the eye?
« Reply #7 on: July 17, 2020, 01:44:47 AM »
Why don't you post a picture.
Offline 1967FEGT
« Reply #8 on: July 17, 2020, 01:50:11 AM »
Bob, Here you are.
« Last Edit: July 17, 2020, 01:52:26 AM by 1967FEGT »
« Reply #9 on: July 17, 2020, 05:29:11 AM »
Bob, Here you are.
This one has two different hose sizes, the correct one will have two of the larger (1/4") hose nipples.
« Reply #10 on: July 17, 2020, 05:54:10 PM »
Bob, Here you are.
That is why I asked Are you wanting something that will work /function or something that will work AND looks the historical part? You can make that part work and function but it is for a different application.
Offline 1967FEGT
« Reply #11 on: July 18, 2020, 10:56:05 PM »
Thanks, Bob. I looked the part number provided by the shot of the MPC.  Three came up on Ebay. The difference is the large in-out on both sides of the valve. It's also 85.00 Vs 25.00. otherwise it did look the same. If the valve functions the same I could easily make it large in-out without anyone being the wiser without removal of the vacuum line.
« Reply #12 on: July 18, 2020, 11:50:36 PM »
A one way valve is a one way valve as far as I know so go for it.
Offline 1967FEGT
« Reply #13 on: July 19, 2020, 03:39:40 AM »
Thank you Bob. I wasn't sure if they worked in the same fashion. I have learned that because they look the same doesn't mean they work the same. It's why I asked you.
« Reply #14 on: July 19, 2020, 04:07:24 AM »
You are correct it is a one way valve.
