Author Topic: Brake and Fuel line mounting locations for a later 1967  (Read 874 times)
Offline Z67Fback
« on: July 12, 2020, 07:26:33 PM »
I am trying to determine the correct locations of mounting hardware of the the fuel and brake line. Specifically for a later 67 with the  2 piece fuel line, routed through the frame rail by the drivers seat,  the brake line line is going under the steering column. I dont see the correct mounting locations for the brake line in the tunnel. Any and all pictures would be greatly appreciated- Thank you!
« Last Edit: July 12, 2020, 08:48:12 PM by J_Speegle »
1967 Fastback, C Code, 4 Sp MT, 7T02C226959 Build Date 4/11/67. Built in Metuchen, NJ
Offline Z67Fback
« Reply #1 on: July 12, 2020, 07:43:33 PM »
I did find a good thread- which may have answered some questions on the fuel line.
http://www.concoursmustang.com/forum/index.php?topic=22685.msg142137#msg142137
Still looking for pictures on locations for mounting hardware for brake line in tunnel
« Last Edit: July 12, 2020, 08:48:19 PM by J_Speegle »
Re: Brake and Fuel line mounting locations for a later 1967
« Reply #2 on: July 12, 2020, 08:02:44 PM »
Brake lines at the drivers side firewall/steering column area is shown in another running change thread
http://www.concoursmustang.com/forum/index.php?topic=20967.msg131858#msg131858
« Last Edit: July 12, 2020, 08:48:27 PM by J_Speegle »
« Reply #3 on: July 12, 2020, 09:04:26 PM »
Reusing the lower drivers side firewall picture from the other thread going rearward to the rear brake flex line.
Sometimes that rear bend at the rear edge of the floor board and tunnel will head up and across the face of the rear inner seat belt anchor with a slight S turn/bend
Offline Z67Fback
« Reply #4 on: July 14, 2020, 10:26:43 PM »
Thank You . Perfect
