Author Topic: 1966 Throttle Linkage  (Read 1266 times)
Offline douglemmo
« on: January 10, 2011, 03:13:02 PM »
I need the complete throttle and kick down linkage setup  for a 1966 289 engine.  I need the pivot which mounts on the fire wall plus the carb. and auto transmission kick down linkages - everything.  Can be rusty, but not corroded or bent or wedled on.  I currently have a complete, restored 1965 linkage set up which is not correct for a 1966 V-8.
Offline 66RavenGTCoupeAgain
Re: 1966 Throttle Linkage
« Reply #1 on: February 07, 2018, 04:52:08 AM »
Hi,
Do you have pictures of you 65 linkage set up at all?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Offline 67gt390fb
« Reply #2 on: February 25, 2018, 08:15:55 PM »
http://www.concoursmustang.com/forum/index.php?topic=8861.msg51685#msg51685
 according to this thread,  the 66-68 throttle linkage  for 289-302  C4 trans is the same part number( i am assuming the  C6ZZ-9725-A was used on 66 289 c4 )
« Last Edit: February 25, 2018, 08:24:40 PM by 67gt390fb »
7R02S153xxx      12/15/66
