Author Topic: Firewall help needed - June 69 Dearborn With Automatic Trans, AC & PB  (Read 1052 times)
Offline truetriplex
I need some help getting the extra hole filled in on my firewall but am not sure as to which are extra, and which belong. Car is a 69 fastback, Dearborn built (6/13), A/T, A/C, P/S R-code.  Can any of you tell me which holes were added, and that I need to fill in?  The car is at the body shop now and they are getting ready to begin work.  Thank you.
« Last Edit: July 06, 2020, 05:02:36 PM by J_Speegle »
Lots of variations based on how the car was equipped and other details. Below is the only hole I was not able to verify.
Maybe someone else has found one there. I didn't. Hope this helps
Offline truetriplex
Thanks Jeff.  What other items or variations come in to play to determine firewall openings? Not knowing Mustangs or Shelby's that well, I am looking to make it as correct as possible since now is the time to close the inappropriate holes.
if its a 70 gt500 it will have added choke cable hole done at kk plant.
Offline 69GT350H
Your marked hole might be for the rubber plug that holds the firewall pad in place?
The one for the plug for the firewall pad is at about 1 o'clock from the hole with the arrow on a bunch of examples. The hole in question is on a flatter/more horizontal surface of the firewall.
You example appears to be from a 70  and possibly a California vapor recovery car for others watching the thread
