Author Topic: 1967 FE exhaust manifold heat riser valve  (Read 554 times)
Offline jswoody
« on: July 02, 2020, 06:35:13 PM »
Does anyone happen to know of source for a replacement spring for the exhaust manifold heat riser valve for a 428 motor?  Any help is appreciated.
« Last Edit: July 03, 2020, 02:42:15 PM by J_Speegle »
Re: 1967 exhaust manifold heat riser valve
« Reply #1 on: July 02, 2020, 06:56:12 PM »
I have a frozen valve for a 1966-67 Ford Thunderbird / Galaxie. Let me check this weekend. I imagine that the springs are the same. I think two springs, bi-metal and coil spring for return tension?
« Reply #2 on: July 02, 2020, 07:02:29 PM »
You think correctly. Flat heat sensitive bi metal spring and small conventional coil spring for return tension. The Galaxie one should be the same IMO.
Offline jswoody
« Reply #3 on: July 03, 2020, 12:46:21 PM »
I am looking for the coil spring.  Thank you very much for looking.
Re: 1967 FE exhaust manifold heat riser valve
« Reply #4 on: July 05, 2020, 11:44:56 PM »
Actually there were 3 springs. One acts as a cushion for the wheel.
Woody, PM me.
