Author Topic: 428CJ Air cleaner Base Change  (Read 1437 times)
Offline cob428
« on: July 01, 2020, 04:40:51 PM »
Any idea when this change happened on the 428CJ aircleaner base.
« Last Edit: July 01, 2020, 07:03:43 PM by J_Speegle »
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Re: 428CJ Air cleaner Base Change
« Reply #1 on: July 01, 2020, 06:54:17 PM »
We have no idea what change you are asking about. What model year?
« Last Edit: July 01, 2020, 07:03:57 PM by J_Speegle »
« Reply #2 on: July 01, 2020, 07:12:08 PM »
Guess (just confirming) your referring to the addition of the hole for the vent on the passenger rear area of the base. In an addition a metal tab was welded to the bottom to hold the attaching hose up out of the way.
If so documents suggest on or around mid Feb 1969 (17th date is listed) TSB info has often been more specific or correct IMHO than some other Ford publications though we could expect that different plants might be different by a day or two on some of these dates
428CJ site has some pictures posted over there.
https://www.428cobrajet.org/id-air-cleaner-69R
Early top left - Later bottom right
« Last Edit: July 02, 2020, 03:50:09 PM by J_Speegle »
« Reply #3 on: July 01, 2020, 07:56:08 PM »
The text from the TSB Article that was published for the week of May 5th 1969
« Last Edit: July 02, 2020, 03:49:53 PM by J_Speegle »
« Reply #4 on: July 02, 2020, 12:39:32 AM »
Here is what the valve looks like that goes into the ram air cleaner.
Offline cob428
« Reply #5 on: July 02, 2020, 12:59:34 AM »
As always thank you for your help
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #6 on: July 02, 2020, 01:12:05 AM »
All it takes is a hole and the valve to convert one base into the other. ;)
Offline rockhouse66
« Reply #7 on: July 02, 2020, 07:54:49 AM »
Nice part Bob!  I have never seen one of those NOS.  And I didn't realize the valve was thermostatic, even though my '69 SCJ car had one.
I think there are 3 variations of the air cleaner base.  Single "hump" underneath, dual "hump" and dual hump with this added valve and the welded on tab to retain the hose.
'66 GT FB
« Reply #8 on: July 02, 2020, 11:37:44 AM »
Did the Q code base go through the same change?
Offline sah62
« Reply #9 on: July 02, 2020, 12:07:45 PM »
The text from the TSB that was published for the week of May 5th 1969
Jeff, it looks like we're both right in the way we described the TSB text (see attached). It's article number 1780 in TSB 114.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline cob428
« Reply #10 on: July 02, 2020, 01:03:47 PM »
Bob,
Should the valve be painted or will be accepted as shown in your picture unpainted?
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #11 on: July 02, 2020, 02:22:53 PM »
Bob,
Unpainted.It was attached after air cleaner base was painted.
« Reply #12 on: July 02, 2020, 03:53:27 PM »
Thanks - corrected my earlier post. Over 30 years no one has noticed that. Guess, so that people can find these, they should be labeled by the TSB Article number
BTW where did you get that scan from? Its different in format from the TSB that I have, which is three columns full width of a 8 1/2 x 11 page. I cut and pasted to fit so I could post it here and still be fairly legible
Offline sah62
« Reply #13 on: July 02, 2020, 08:41:51 PM »
I got it from a TSB Index PDF file that was downloaded from here: https://fordification.com/downloads/downloads.htm
Scott Hollenbeck
« Reply #14 on: July 03, 2020, 12:31:21 AM »
The build sheet has different ford eng, id also for the air cleaner so that can tell you when the change was made also.
« Last Edit: July 03, 2020, 12:39:45 AM by specialed »
