Author Topic: When is a Mustang a 64,5??  (Read 9609 times)
Offline Toploader
Re: When is a Mustang a 64,5??
« Reply #30 on: October 20, 2013, 04:14:55 PM »
It's common to confuse gear ratio with overall steering ratio. The overall steering ratio for the G.T. would be 21.7.
76A-Y-D2-13H-72-6-6
Offline cobraboy
« Reply #31 on: October 20, 2013, 05:48:41 PM »
OK  I see that if the pitman arm on a box moves through 90 degrees  - lock to lock and it takes 4 turns on a GT box to do this then to move the pitman arm 360 degrees  ( 1 turn ) it would take 16 turns = 16 :1, the gear ratio.
I have only seen the spec of 16:1 given.
Do you know how the overall steering ratio of 21.7 :1 is calculated ?
I am curious thats all   :)
Would it be how many turns on the steering wheel to move a road wheel 360 degrees ( if it could ?)
« Last Edit: October 20, 2013, 05:52:38 PM by cobraboy »
13th April 1965 Dearborn K GT on the other side of the pond.
Online CharlesTurner
« Reply #32 on: October 20, 2013, 09:05:04 PM »
Probably best to start a new thread discussing steering box specs... easier to search in the future and allows the best exposure to get input from others.
Offline Toploader
« Reply #33 on: October 21, 2013, 05:27:01 PM »
76A-Y-D2-13H-72-6-6
