Author Topic: water pump painted?  (Read 503 times)
Offline fmr187
water pump painted?
« on: June 28, 2020, 12:10:46 PM »
On a 65 with aluminum water pump is the pump and fan spacer painted or natural? From looking thru the pictures I have seen both. What did Ford do?
65 Convertible born in Dearborn on Feb 10
Re: water pump painted?
« Reply #1 on: June 28, 2020, 12:33:05 PM »
spacer unpainted but pump is block color.
« Reply #2 on: June 28, 2020, 01:46:31 PM »
I'm more concerned with your sources. I hope they were not on this forum. That being said, whatever they were, the ones that showed a contrary painting -
- should be viewed in the future as not very reliable.
Offline fmr187
« Reply #3 on: June 28, 2020, 03:18:28 PM »
Yes this site. In Picture section Sept 64 Dearborn and Fall 64 Dearborn cars appear to be unpainted. Jan 65 Dearborn and Early 65 Dearborn cars have black pumps. This let me to the question. Thanks
« Reply #4 on: June 28, 2020, 04:47:39 PM »
It may be a pic like this one:
In this thread:
http://www.concoursmustang.com/forum/index.php?topic=19329.0
However, the caveat of "Disclaimer: :) As always we need to warn that unrestored does not always mean unaltered by previous owners" should apply here.
In this case it may mean the water pump was replaced or the paint wore off.
Also note that aluminum pumps do not require paint to be rust free. Cast iron rusts so it requires paint.
« Reply #5 on: June 28, 2020, 05:33:19 PM »
Not unusual for the paint to not stick as well to aluminum when compared to steel parts. Paint can be stripped off when the parts were cleaned during a water pump or timing chain replacement at a shop or if the engine has been power washed at the coin self car washes as many of us can attest to. There are even a couple of period pictures of fairly new 65's but since it is so contrary to all the original engines and pictures we have access to this one or two examples (especially since they were magazine cars) its been accepted by most that the water pump and or housing had been removed or replaced for some reason.
Just wanted to mention before one of those two pictures get posted ;)
fmr187 - Good question and thanks for bring it up since sure others have seen the same pictures and may have assumed the same
Might I suggest pictures from the era posted in The Assembly Line - Section under the Sub-Assembly & Supply Plants Sub-section
64 Cleveland Engine Plant V8 Oil Pressure Test
Early Small Block Product Test Pictures
« Last Edit: June 28, 2020, 05:35:38 PM by J_Speegle »
