Author Topic: holley carburetor help  (Read 1424 times)
Offline cob428
« on: June 25, 2020, 03:31:54 PM »
1969 automatic part number on carburetor C9AF-9510-N I went to install the choke tube rubber vacuum line and the port is not there any ideas?
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Offline Coralsnake
Re: holley carburetor help
« Reply #1 on: June 25, 2020, 03:47:28 PM »
Is there a hole for it under the lip?
« Reply #2 on: June 25, 2020, 04:12:51 PM »
+1 . First thing I would want to see is a view of where the nipple typically is or if opening is missing or is plugged. If hole is missing a view of the list number area to determine of if any tampering .
Offline cob428
« Reply #3 on: June 25, 2020, 04:51:31 PM »
Is this what you are looking for Bob?
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #4 on: June 25, 2020, 06:01:45 PM »
There will be a hole under the lip where the arrow is pointing. The 1/4" steel tube is missing.
« Reply #5 on: June 25, 2020, 06:41:37 PM »
First off we need to determine if the tube that is supposed to be there is missing or plugged .
   If the hole is is not there at all is when the air horn data needs to be looked at to see if it has been counterfeited.
Offline cob428
« Reply #6 on: June 25, 2020, 10:23:16 PM »
Well great news for me the hole is there. Now hopefully its not bad news how do I find one, buy an old carb?
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #7 on: June 25, 2020, 11:59:27 PM »
Donor carb body or make one
« Reply #8 on: June 26, 2020, 10:49:12 AM »
I had the exact same problem about 3 weeks ago on a C8OF AA carburetor. I cut a piece of 1/4" cupronickel plated steel tubing about 2" long and then drove it into the hole with a brass punch and a rubber mallet. The original part was gold dichromate cad plated 1/4" steel tubing.
« Reply #9 on: June 26, 2020, 01:13:14 PM »
If you find something you can send it to me and I will refinish it for you in zinc gold @no charge for postage. Make sure it will fit. ;)
Offline Drew Pojedinec
« Reply #10 on: June 26, 2020, 03:36:43 PM »
I made hundreds of them out if steel tubing and replated them.
Not a big deal.
Offline 6t9m1
« Reply #11 on: June 27, 2020, 08:12:09 AM »
After reading the above posts I agree with the position and will also add mine is 2 and 5/8” of an inch long.
¼” diameter.
Correct me if the tube has been replaced.
May69 Mach1 SanJose 351toploader
Offline ninedrvr
« Reply #12 on: June 30, 2020, 02:47:38 PM »
I bought a C9AF-N reissue carb from Carls Ford Parts a while back. That tube was missing on the carb I got. He sent me a brand new tube for me to tap in place after I removed the plug that Holley had installed on the carb. If you don't find yours give him a call.
http://www.carlsfordparts.com
« Reply #13 on: June 30, 2020, 04:47:28 PM »
Going to move the topic since it is not Shelby or 69 specific and a wider viewing audience might benefit
