Author Topic: DAR mixing  (Read 4094 times)
Offline T Lea
DAR mixing
« on: January 08, 2011, 08:56:34 AM »
Anybody have a mixing, MSDS sheet for Delstar DAR? PPGs website is not user friendly. I also need one for PPG flattener
Re: DAR mixing
« Reply #1 on: January 08, 2011, 09:29:26 AM »
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: DAR mixing
« Reply #2 on: January 08, 2011, 09:42:04 AM »
I have learned that when searching for paint product MSDS's and Product Data Sheets for jobs we are doing at work, I don't get trapped in a revolving door by going to the MFG website.  Instead, I Google a string something like this:
SEARCH BOX ENTRY     PPG delstar MSDS PDF      or    PPG Deltar flatener PDF
In my experience, this will get right whereyou need to be.  These documents are usually in PDF format and by putting that in the search string, it filters out all the riff-raff.
« Last Edit: January 08, 2011, 09:43:53 AM by bryancobb »
66 Metuch Conv
Nightmist, Std Blu Int
Offline bryancobb
  • 2009 Ridn' Around
66 Metuch Conv
Offline gtamustang
  • CPM
Re: DAR mixing
« Reply #4 on: January 11, 2011, 02:35:08 PM »
Tim,
What are you going to use the PPG DAR with flattener for? Engine paint? I did that on the yellow coupe. Came out ok...seems a little thick compared to the original Ford engine paints.  Also, I have all of the MSDS sheets for the DAR products.
Regards,
Pete Morgan
Offline T Lea
Re: DAR mixing
« Reply #5 on: January 11, 2011, 05:06:34 PM »
Yes. I've used it in the past with great results but lost my mixing sheets. I printed them from the links above, thanks to all.
