Two additional documents are posted in one pdf found in the Library under 1969 and then down towards the bottom under the Special Service Letters, Service Campaign Documention and Recalls section. It talks about an issue they had at some or all plants where the newly introduced larger bearing rotors mistakenly got installed on the standard spindles and how dealers should address the issue. Second part of the document (last four pages) describes how to inspect a Boss 302 (or really any car equipped with the new heavy duty spindles, bearings and rotors) for the right parts and how to address the issues if the findings are different than expected.
Last diagram shows the spindles were identified in the document as having blue paint on the steering arm of the spindle. On original cars a medium blue has been documented many times and a few with a more teal coloration also.
Titled -
69 Disc Brake Spindle and/or Hub and Rotor Mismatch
Campaign #668 (Ford of Canada) Letter- July 11, 1969
