Author Topic: Shock Tower Outer Cover Correct Bolt Direction - Dearborn  (Read 414 times)
NOTE: The first couple of posts have been split from another thread so that discussion can continue on this plant and time period
I have seen conflicting pics of "Non Restored" Vehicles that have the Outer Shock Tower Cover bolts installed differently.  Some cars have the bolt head in the engine compartment and some cars have the Nuts on the engine side.  Which is correct for a January 65 San Jose Car ?
That head direction (the nuts were in the engine compartment) was a Dearborn "quirk" in 1965. I don't remember the dates, but from what I do remember, it was "narrowed" down to a single shift (there were 3 at the time) and possibly a single worker. I searched the forum but could not find anything. For the rest of the 64 thru 66 builds, and at all plants, the bolt head is in the engine compartment.
« Last Edit: June 18, 2020, 09:10:25 PM by J_Speegle »
Offline Hipo giddyup
Re: Shock Tower Outer Cover Correct Bolt Direction - Dearborn
« Reply #1 on: June 16, 2020, 11:43:21 AM »
Referring to Jim's comments:
  From the 66' model year in the  "1966 Unrestored section", a December 1965 DEARBORN build showing the nuts inward in the firewall compartment.
« Last Edit: June 16, 2020, 11:45:32 AM by Hipo giddyup »
Offline FXguy
    • Early 64 June K Convertible Restoration
« Reply #2 on: June 18, 2020, 02:09:46 PM »
I have two June K code convertibles, less than 100 units apart.  Bolts heads on the inside of the engine compartment on one, heads in the fender well on the other.  Also interesting is that the fender top bolts on one use star washer, on the other disk washer.
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
