Author Topic: 65 starter solenoid  (Read 571 times)
Offline Broncobuilders
65 starter solenoid
« on: June 17, 2020, 02:24:29 PM »
Should my 65 289 starts solenoid be black or brown? Also, should it have the ford stamp on top
1965 c code convertible
1966 A code convertible
Online CharlesTurner
Re: 65 starter solenoid
« Reply #1 on: June 17, 2020, 03:09:27 PM »
What's the scheduled build date of the car and assembly plant?
« Reply #2 on: June 17, 2020, 07:43:12 PM »
The scheduled build date is 22S, the DSO is 23
« Reply #3 on: June 17, 2020, 08:10:32 PM »
Should be black with most likely block FoMoCo for that late of a car.  The brown one was possibly only used the first part of '64.
FYI, the DSO is the district sales office the order came through.  The assembly plant is the second character of the VIN.  In your case it would F, R or T... assuming we are talking about a Mustang here.
« Reply #4 on: June 17, 2020, 08:15:13 PM »
Thank you very much. Mine is a 75 c code convertible. The second letter is F. What plant is that?
« Reply #5 on: June 17, 2020, 08:17:38 PM »
Sorrry, my previous post says my car is a 75. It’s a ‘65
« Reply #6 on: June 17, 2020, 08:33:09 PM »
"F" would indicate Dearborn. Yours likely starts 5F0873.....
Looking through the pictures found the following
5F689xxx Oval
5F703xxx Rectangle
The FoMoCo seems to be a running change or indicate two different suppliers or plants. If you care there will also be a date indicating when it was made on the bottom of the case on the metal cover but for your car's plant and time period I hope this helps
PS- welcome to the site. You might find it helpful to add  your cars information to your signature since you will need to include it in most questions you post.
« Last Edit: June 17, 2020, 08:55:40 PM by J_Speegle »
