Author Topic: Spring Perches 69 BOSS 302  (Read 2434 times)
Offline 69BOSS302
« on: June 16, 2020, 11:49:30 AM »
Hello all, I was curious if anyone knew the date that FORD went from the block script to the oval on the perches. Here is a reference from Marcus suspension guide. My car is an May 23 built BOSS 302
Thank you
Philip
69 BOSS 302
9F02G198123
May 23, 1969 - Dearborn
Re: Spring Perches 69 BOSS 302
« Reply #1 on: June 16, 2020, 01:55:23 PM »
Thank you
Philip
As Marcus indicated it is only a guesstimate given there is no documentation other then observations by our peers at this point in time. Your date is right in a change over point . I would error on the side of caution and try to use the harder to find Fomoco in the rectangle trademark all other things being equal. FYI worse case scenario this kind of nuance difference is not relevant in MCA trailered concours deduction determinations.Just my opinion others may have different.
Offline 69BOSS302
« Reply #2 on: June 16, 2020, 02:35:45 PM »
Okay, thank you Bob. BTW, form another thread you were helping me on; I did finally manage to acquire 69 hubs and rotors! Yahoo!!!
Thank you
Philip
69 BOSS 302
9F02G198123
