Author Topic: Convertible Top Frame  (Read 8250 times)
Offline slim
Re: Convertible Top Frame
« Reply #15 on: January 09, 2011, 04:07:02 PM »
Oz390/AKA dalorzof I also testify to the extensive research you've done on 65-68 vert tops. Your lime gold 68 is hands down beeeeutiful!
68 Mustang vert. 289 2V, automatic, power disc brakes, power steering, factory AC.
Lime gold, black top with glass window. Standard black interior.
Offline 68 S Code
« Reply #16 on: January 10, 2011, 10:08:11 PM »
Slim I see you are in my region. Are you near Milwaukee? I would like to possibly have a  look at your 68 vert top frame. Oz and have been conversing quite a bit the last few days.
Offline yelostang
« Reply #17 on: January 17, 2011, 11:15:13 AM »
To Oz 390. Saw a newscast on flooding in Brisbane and thought of you. Hoping that all is OK with you and yours.
Offline 68 S Code
« Reply #18 on: January 19, 2011, 12:43:02 AM »
After disassembling the frame noticed that the header is pretty corroded. Its either a pot metal or potentially magnesium. Not sure. Oz mentioned it's
Pretty normal to have to do some reconstruction with filler. Im concerned with it popping in the future. Thought about using either JB weld or this plumbers epoxy clay vie used before to repair steel tubs. Any suggestions or recommendations? I would prefer to just get a nice one and just replace it. If anyone knows someone who has a trashed 67 or 68 vert top I only need the header to be salvageable.
« Reply #19 on: January 19, 2011, 01:11:11 AM »
The header you describe is probably the condition of a large percentage of other ones out there.  They can be repaired with something like all-metal.  Most trim shops will just put tape over the pitting and then maybe a piece of foam headliner material to smooth it over.
Offline 68 S Code
« Reply #20 on: January 19, 2011, 02:32:30 PM »
Isn't all metal like bondo with metal fillings? Silver appearance in the can.
« Reply #21 on: January 19, 2011, 03:14:49 PM »
Yep, that's exactly what it is.
Offline 68 S Code
« Reply #22 on: January 19, 2011, 06:39:58 PM »
Had some 20 years ago. I presume it's still available?
So caspian am I to believe that I may as well work with what I have as most that are out there have the same type of corrosion as mine does or some level of damage.
« Reply #23 on: January 19, 2011, 07:13:39 PM »
I'd suggest blasting it first to clean out all the corrosion.  So long as there is no damage to attaching areas, you can probably work with it.
Offline Oz390
« Reply #24 on: February 04, 2011, 08:10:36 AM »
Would also suggest to anyone restoring a top to heli-coil the taps for the latch truss head screws... commonly worn and sloppy, and an easy fix....
8R03S : 76A I 2A 15M 72 5 U
