Author Topic: Carter X Fuel Pump  (Read 1668 times)
Offline 1970 Snake
Re: Carter X Fuel Pump
« Reply #15 on: June 09, 2020, 12:12:41 PM »
Thanks Royce, I did all the oil gallery mods, top end restrictor and correct down positioning of the rocker shaft holes. I did all the assembly and measured all bearing clearances and all within spec. Yes cold start I am getting your defined readings with 10-30 comp cams break-in oil with 80 psi at 2K rpm. Run temp idle 20 psi, 2500 rpm 45 psi, 4000 rpm 65 psi. After doing a bunch of reading online its seems pretty standard to have 10-15 psi or less at idle on a run temp engine. As you can see from my engine test run stand pic I am also running an engine oil cooler setup (cooler bypassed) which also has a relief in it, I am assuming that will not have an impact on engine oil pressures.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
« Reply #16 on: June 09, 2020, 12:20:45 PM »
That's mighty thin oil. Might make better pressure with a more typical oil for FE's like Valvoline Racing 20W-50.
Oil cooler should make no difference in pressure.
Everything that you mention sounds normal with 10W-30 on a hot day.
Offline 1970 Snake
« Reply #17 on: June 09, 2020, 12:46:50 PM »
Thanks, yes was planning on running 20-50 later, thinking possibly Amsoil Z-rod synthetic after 1 or 2K on the engine, just wanted the 10-30 for break-in and initial easy running.
« Reply #18 on: June 09, 2020, 12:56:56 PM »
If it's a flat tappet cam I would drain the oil after the 20 minute lifter break in. Install Amsoil if you like, it won't hurt anything nor will it justify its higher price.
Offline 1970 Snake
« Reply #19 on: June 09, 2020, 02:39:08 PM »
Yes definitely changing the oil and filter now after the break-in run yesterday. LOL is there anything cheap in this hobby, I like the AMSOIL Z-ROD Synthetic Motor Oil formulation as it is specifically designed for classic and high-performance vehicles, and has a high-zinc content to help prevent wear on flat-tappet camshafts, which I am running, and its blended with rust and corrosion inhibitors for additional protection during long-term storage. I was just thinking I would run a non-synthetic quality high zinc oil for the first 1000 miles or so for additional run in and then go to the synthetic, although there are a number of schools of thought around the whole topic of engine break-in and when to run synthetic. Thanks for your input.
Offline 70cj428
« Reply #20 on: June 09, 2020, 08:56:08 PM »
"I also check the Carter X for fuel pressure and it puts out about 7 psi dead headed against a pressure gauge I put on the temporary fuel line when I had the carb removed."
7 psi is kinda pushing it with the stock Holley carb. The fuel pressure is determined by the spring on the pump diaphragm. I have a little over 5 psi from a rebuilt 4441X pump on my q code. Where did you get your rebuild kit ?
Offline 1970 Snake
« Reply #21 on: June 09, 2020, 09:53:33 PM »
Good to know we have the same numbers, the speed shop told me that the holleys will handle 8 psi but if I was running a Edlebrock they don't like more than 5 psi.
I can't remember where I got the kit, its been a while and I buy parts from many different vendors.
Offline 1970 Snake
« Reply #22 on: June 13, 2020, 10:52:16 AM »
Just a follow up I rechecked my rebuilt Carter X fuel pump with a better gauge dead headed on the to carb fuel line and it puts out exactly 6 psi, not a big difference from my original 7 psi reading but more accurate.
