Author Topic: 1967 390 smog  (Read 4312 times)
Offline dan green
1967 390 smog
« on: January 04, 2011, 10:42:26 PM »
Does anyone have any pics of a 67 "S" code 390 smog system?  Particularly the hose configuration?
Offline 68 S Code
Re: 1967 390 smog
« Reply #1 on: January 04, 2011, 11:27:01 PM »
I don't have a pic but see if you can get someone with a 67 Osborn chassis manual to scan and email it to you. I believe the 68 manual covers the routing of the hoses and vacuum lines. All I have for a 67 is a smog pulley.
Offline dan green
Re: 1967 390 smog
« Reply #2 on: January 05, 2011, 10:16:12 AM »
I looked at the Osborn Assembly Manual but it doesn't seem that a system was actually assembled in that way.  It would be nice to see an actual assembly line example.  This seems to be a very rare system and its not likely to see an original example.
Offline C9ZZ-16228-B
Re: 1967 390 smog
« Reply #3 on: January 05, 2011, 11:36:02 AM »
Is your car with or without A/C?
Offline dan green
Re: 1967 390 smog
« Reply #4 on: January 05, 2011, 05:55:05 PM »
Without A/C.
Offline T Lea
Re: 1967 390 smog
« Reply #5 on: January 05, 2011, 07:53:31 PM »
Dan, there were about 3 different versions of 67 BB smog so include your build date.
Offline KDunne
Re: 1967 390 smog
« Reply #6 on: January 05, 2011, 09:22:37 PM »
Offline dan green
Re: 1967 390 smog
« Reply #7 on: January 05, 2011, 11:08:33 PM »
Built Sep 19, 1966.
Re: 1967 390 smog
« Reply #8 on: January 06, 2011, 12:20:04 AM »
A little help for you as I look for a related picture or graphic
Hoses -
#1 - from the air filter canister to the back of the pump - far outer one on passenger side
#2 - from driver side head tube to back of the pump - far outer one on the drivers side of pump
#3 - from the T at the rear of the engine (passenger side) to the pump - attached to the center hose nipple
#4 - from the passenger side head tube to the T (nipple in the middle of the T)
#5 - from the rear end of the T to the divert er valve - rear most nipple with the valve attached to the intake
#6- from the divert er valve to the PVC valve (other hoses and attachments)
#7 - From hard vacuum line (attached to the divert er valve) to the vacuum block attached to the intake manifold in front of the carb
Offline T Lea
Re: 1967 390 smog
« Reply #9 on: January 06, 2011, 08:10:35 AM »
Unfortunately not on the car but this came off a Sept built S code,
Offline dan green
Re: 1967 390 smog
« Reply #10 on: January 06, 2011, 11:08:43 AM »
Thanks.
Looks like there are extra fittings at the PCV.
Can you see the number on the belt?  Is it the same size as the later CJ system w/o ac running off of the fan pulley only?
Re: 1967 390 smog
« Reply #11 on: January 06, 2011, 12:16:13 PM »
Here are some pics from an 09J San Jose car I have lying around...
