Author Topic: I have a C7AF1113A Starter (Sep/66) for FE  (Read 894 times)
Offline Daisy
« on: June 02, 2020, 10:23:46 AM »
I replaced my worn starter and get $40 core charge refunded if I turn in the old one.
Old one is worn (slow to crank when engine hot) and new one is great (fixed the issue).
So...  is this a valuable part for rebuilt/concours GT500 or S-Codes or should I just take the $40 and run?
Thanks!
("Daisy" is a 1967 S-code coupe born 21 Sep '66 in San Jose....)
Daisy is a 1967 Mustang Coupe
Frost Turquoise
White Vinyl Top
390/C6
Re: I have a C7AF1113A Starter (Sep/66) for FE
« Reply #1 on: June 02, 2020, 11:08:34 AM »
keep it.....doesn't take up much space.
« Reply #2 on: June 02, 2020, 12:42:55 PM »
Thanks!
It all depends on what ti looks like. How many times it was rebuilt and how many original parts have been replaced with parts from later starters? The condition of components like rust pits e,damge etc. Does the barrel have metal stamped numbers and letters and if so what are they? Motorcraft would be not be useful.
« Reply #3 on: June 02, 2020, 05:58:31 PM »
May instead have the ink stamping on the main body so check for that also if you can't find the stamping in the metal as Bob's described.
Related thread with pictures of both methods of marking that may help
http://www.concoursmustang.com/forum/index.php?topic=14384.0
« Reply #4 on: June 02, 2020, 08:17:52 PM »
Show us a few pictures.The aluminum snout is one area of particular interest as are any numbers in the barrel. The end plate with the brushes. You get the idea.
« Reply #5 on: June 02, 2020, 11:27:18 PM »
Cool if it does but don't get your hopes up because if the starter has been rebuilt even once it will not have a factory ink stamp.
« Reply #6 on: June 03, 2020, 12:09:15 AM »
And as Bob mentioned possibly not even the main body was reused. These are often Frankenstein like assemblies
Offline Daisy
« Reply #7 on: June 10, 2020, 12:24:38 PM »
Thanks for the replies!
Same starter since at least 1983.  Rebuilt before? Unknown.  Car had 100K mikes when bought used.
Frost Turquoise
White Vinyl Top
390/C6
