Author Topic: A/C HOLES IN RADIATOR SUPPORT  (Read 532 times)
Offline KyWhitec5
« on: May 31, 2020, 03:33:01 AM »
I replaced my Radiator support on my SJ FB and I'm also adding a factory under dash A/C unit.  My question is how to locate the holes for both the upper and lower holes ? Is there specific dimensions for locating them and what is the correct hole sizes.  Thanks
1965 FB San Jose
5R09A179303
63A
M COLOR
65 TRIM
28A DATE
51 DSO
1 AXLE
6 TRANS
Offline 196667Bob
Re: A/C HOLES IN RADIATOR SUPPORT
« Reply #1 on: May 31, 2020, 02:49:40 PM »
While I am not as familiar with 1965's as my 66, and I do not have a 1965 Assembly Manual, I would think (?) that 1965 would prove similar. I have attached a copy from the 1966 Assembly Manual ; hopefully you can find the same two dimples on your 65 as are noted on the 66.
Hope this helps,
Bob
MCA 04909
« Reply #2 on: May 31, 2020, 04:18:48 PM »
It's in the 65 Mustang Electrical Assembly Manual (AM0008, pg 49 and 56). The A"C under dash unit drain is documented there too.
If you don't have a set of Mustang Assembly Manuals for your car's year, I strongly suggest you get a set.
Offline rockhouse66
« Reply #3 on: May 31, 2020, 07:38:17 PM »
I think you can see the holes in these pictures.
'66 GT FB
Offline 196667Bob
« Reply #4 on: May 31, 2020, 08:39:58 PM »
yes Jim, those are the holes. However, they are in a car that has, or had previously, A/C. As the OP is adding A/C, as well as replacing his Radiator Support, unless his replacement Radiator Support came from a car that originally had A/C, there would only be dimples there, showing where to drill (or punch) the 1-1/4" holes.
Bob
MCA 04909
