Author Topic: fuel line clip  (Read 743 times)
Offline fmr187
fuel line clip
« on: May 30, 2020, 07:57:41 PM »
Is the fuel line clip that is closest to the sending unit the same clip that is used to attach to the trans tunnel? From the Osborne manual it looks like a different part number but I don't see any other clip available in the parts catalogs?
65 Convertible born in Dearborn on Feb 10
Re: fuel line clip
« Reply #1 on: May 30, 2020, 11:08:57 PM »
No the ones in the driveline tunnel retain both brake and fuel. Back there it only needs to hold one. Think this is the one your looking for - just confirming. That one is a J or hook shape while the majority of the others are a strap style that wraps around both lines
Offline fmr187
Re: fuel line clip
« Reply #2 on: May 31, 2020, 01:21:37 PM »
Jeff, that is not the clip that I am referring too. There is a hole in the vertical part of the trunk floor to the left of where the fuel line meets the sending unit. I am assuming that there should be a clip there, maybe not.
Re: fuel line clip
« Reply #3 on: May 31, 2020, 07:42:51 PM »
Ok now we are both on the same "page"
This one is from a Dearborn convertible 5F270xxx. Car was fully undercoated/sprayed with some product when it was new so colors and finishes are a bit off in many areas shown in the pictures
Couple of pictures from San Jose examples ( closer and clearer ) The top from 65 and the lower from a 66 example. Believe they are both the same
Offline fmr187
Re: fuel line clip
« Reply #4 on: June 02, 2020, 08:41:10 PM »
Yes that's what I am referring too. Is this clip available anywhere? I haven't seen anything like it.
Re: fuel line clip
« Reply #5 on: June 02, 2020, 11:23:22 PM »
I know AMK carries the 67-70 version but not sure about 65/66.
Re: fuel line clip
« Reply #6 on: June 03, 2020, 12:29:19 AM »
Always got them from donor cars. Think the Falcon could have the same design but not certain
Re: fuel line clip
« Reply #7 on: June 03, 2020, 12:34:38 AM »
Try 377119-S32, AMK B-10274, 2 each, $3.
