Author Topic: Heater Hose Strap  (Read 614 times)
Offline bjf1992
Heater Hose Strap
« on: May 25, 2020, 09:42:45 PM »
Did the A/C cars use this heater hose strap??
https://www.deadnutson.com/heater-hose-aluminum-strap/
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Re: Heater Hose Strap
« Reply #1 on: May 25, 2020, 09:51:16 PM »
A/C hoses used a different rubber one. The aluminum one was used on the heater hose according to the assemblyline manual however they did not end up on every car IMO.
Offline bjf1992
« Reply #2 on: May 25, 2020, 11:20:14 PM »
Perfect. Thanks again Bob. Can’t wait to see you’re shop one of these days!!
« Reply #3 on: May 26, 2020, 05:45:53 PM »
If the straps were used there seems to be the possibility that different materials were used depending on assembly plant. Likely due to different suppliers
BTW you might want to add where your car was built in your signature. Thanks for adding what you have
