Spent some time over the holidays creating a complete sub assembly of the steering linkages, centerlink, ps control valve, ps cylinder w/ bracket and ps hoses. Looks pretty good so I moved back to finishing the upper control arms. Read in the shop manual that you need to put a pipe brace next to the shaft, spanning from side to side of the arm, before tightening the large shaft bushings/end caps per specs. I checked the torque specs and can't find one for these bushings/caps in the charts. Can someone list the required torque? Also what are you using instead of the pipe. Hate to scratch up the nice finish. To those who mentioned the gun bluing for a heat treated look, thanks. Worked like a charm on the tie rod sleeves. Couldn't believe how easy it was.
