Author Topic: Correct fuel pump gasket  (Read 483 times)
Offline Hipo giddyup
« on: May 22, 2020, 05:07:58 PM »
I have a bunch of C3AZ-9417-C fuel pump gaskets but I wanted to check and see if these are correct for a 66’ 289 application? I’ve tried doing searches but not finding any pics to verify?
Re: Correct fuel pump gasket
« Reply #1 on: May 22, 2020, 05:15:40 PM »
Your picture shows orange and the typical vintage gasket used had blue highlights. As long as you don't see the orange once the gasket is mounted you will be fine.  I would make the orange disappear if I was going to use them.
« Reply #2 on: May 22, 2020, 05:58:27 PM »
Good example of NOS/service replacement parts being farmed out to different sub contractors over the years. Haven't seen that name or pattern in the past
« Reply #3 on: May 22, 2020, 11:49:50 PM »
Thanks for your input. I will say, these are quite stiff, well made gaskets to what could be purchased today. They are closer to an exhaust manifold gasket, a very hard gasket overall.
