Author Topic: Firewall Clips  (Read 683 times)
Offline bjf1992
Firewall Clips
« on: May 20, 2020, 07:51:27 PM »
Was wondering if anyone here could tell me what goes where. My disassembly pics aren't clear.
I have the C6 shifter light wire currently hanging from a J hook in the green circle, but not sure if that's correct.
I'm thinking the shifter light wire and reverse light wires maybe both hung from a plastic loop in this location (or maybe the blue location) instead??
'69 Cougar Convertible, Dearborn, April 2nd build date
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Re: Firewall Clips
« Reply #1 on: May 20, 2020, 11:02:48 PM »
This may not be on your agenda but the firewall sealer needs to be applied around all of the things that come through the firewall before any clips are aplied. I thought I would remind you just in case you were trying to do things the concours way.
Offline bjf1992
Re: Firewall Clips
« Reply #2 on: May 20, 2020, 11:33:26 PM »
I know I probably should add the sealer, but it looks so nice without.
So far I haven’t been able to bring myself to put it on :)
Re: Firewall Clips
« Reply #3 on: May 20, 2020, 11:59:31 PM »
Your window for deciding is closing given the next steps . ;) Trying to do a decent job with the engine in for instance is very problematic. If you don't mind it not looking assemblyline then don't worry about it.
Re: Firewall Clips
« Reply #4 on: May 21, 2020, 01:15:16 AM »
Maybe this will help. 428Cj with auto - Dearborn
Using the plastic loop style Upper stud not being used
Offline bjf1992
Re: Firewall Clips
« Reply #5 on: May 21, 2020, 02:04:34 PM »
Perfect! Thanks again!
