Author Topic: Axle Housing Date Stamp?  (Read 1522 times)
Offline Mike_B_SVT
« on: May 18, 2020, 09:48:19 PM »
Found this stamp on my axle housing when I was cleaning it up the other day.  I know they weren't stamped with the VIN, but could this be a Date stamp?
Located on the front of the tube on the passenger side:  2F
Possibly June 2nd?  Or "Week 2 of June"?
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Re: Axle Housing Date Stamp?
« Reply #1 on: May 19, 2020, 12:56:17 AM »
Sorry I don't have the answer. Not enough found and collected to form a pattern so far
« Reply #2 on: May 20, 2020, 11:53:33 AM »
I recently cleaned a 9'' housing and found 9 B stamp in same area but after paint its very hard to see.
Offline Mike_B_SVT
« Reply #3 on: May 20, 2020, 07:02:56 PM »
Thanks Ed, and Jeff!
Hopefully others will come along and add some info in the future :-)
Mike B.
Cat Bites Man!
« Reply #4 on: May 21, 2020, 12:57:53 AM »
Well at least now you have some "feeler" threads posted around the web to catch others attention and hopefully this will pay off over time
Offline Mike_B_SVT
« Reply #5 on: May 26, 2020, 02:33:07 AM »
Popped in to West Coast Classic Cougars last week to pick up some parts.  Took a look through their axle piles while I was there.  Found a few stamped housings, but not sure exactly what they came out of.  Thought I would share the findings though.  I also included pics of the housings themselves because you knowledgeable folks will probably be able to glean some info from them.
This first one looks like maybe a "2H"
« Last Edit: May 26, 2020, 02:42:53 AM by Mike_B_SVT »
Mike B.
Cat Bites Man!
Offline Mike_B_SVT
« Reply #6 on: May 26, 2020, 02:38:35 AM »
Definite 3J on this housing.  Center section was date 1K21, although I don't know whether or not it is original to the housing.
Mike B.
Cat Bites Man!
Offline Mike_B_SVT
« Reply #7 on: May 26, 2020, 02:44:19 AM »
This one looks like another 2H to me.
Mike B.
Cat Bites Man!
Offline Mike_B_SVT
« Reply #8 on: May 26, 2020, 02:46:30 AM »
Last one is stamped something A...
Mike B.
Cat Bites Man!
« Reply #9 on: May 26, 2020, 05:28:50 PM »
Thanks for sharing your findings so far Mike
Sure others will keep an eye out for the stampings in the future
BTW - you mentioned Passenger side tube on the first post. Have all the others been in the same location?
« Last Edit: May 26, 2020, 05:31:24 PM by J_Speegle »
Offline Mike_B_SVT
« Reply #10 on: May 26, 2020, 09:23:32 PM »
Yessir, front of the passenger side of the tube.
Mike B.
Cat Bites Man!
Offline boss167961
« Reply #11 on: May 30, 2020, 02:53:53 AM »
Mine is 3E, which fits with the June build date of the car
Martin
Offline ExportMach
« Reply #12 on: August 11, 2020, 05:42:44 PM »
I found the stamping on my housing as I was recently sanding it for primer. Mine as a '2' plus either an 'H' of an 'F'. The '2' is less pronounced at the bottom and the second character has a vertical leg like an 'H' of 'F' and the cross leg.
Mark C
