Author Topic: 1967 Mustang/Cougar Vacuum Tilt Steering Column  (Read 555 times)
Offline Snydly289
« on: May 18, 2020, 09:00:56 PM »
For sale is a 1967 Mustang / Cougar Factory Vacuum Tilt Steering Column. It is not complete as it is missing parts here and there. Not intended to be a direct swap.
I have not had this column installed on a working car so I am unable to verify if all of the tilt mechanisms work fully at this time.
The harness is un-spliced, plastic connector is not broken and pins are intact as well as the upper plastic portion/horn contacts of the harness.
There are two dents on the column, one at the base of the tube, and one on the upper removable steel collar.
The inner steel spring inside the plastic vacuum canister is rusted and broken, but plastic housing is intact.
If additional pictures are needed or info, please contact me.
Item has now been listed as an auction on eBay, please see "Parts on the Web" section
« Last Edit: June 14, 2020, 12:21:15 AM by Snydly289 »
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
