Author Topic: A-Pillar Antenna Wire Hole  (Read 3377 times)
Offline ninedrvr
« on: May 18, 2020, 03:56:04 PM »
Did the 69 cars get the hole in the A-Pillar for the antenna wire?
Re: A-Pillar Antenna Wire Hole
« Reply #1 on: May 18, 2020, 04:11:41 PM »
Yes believe it was stamped in the panel at the stamping plant
Offline ninedrvr
« Reply #2 on: May 18, 2020, 04:53:39 PM »
So that means it would have a plug installed as would the radio delete Mustangs
« Reply #3 on: May 18, 2020, 07:02:42 PM »
Not a plug but two plugs . One small diameter one from the forward inner structure and one where the antenna wire goes through the hinge structure.
Offline ninedrvr
« Reply #4 on: May 18, 2020, 07:41:08 PM »
Any pictures of these plugs or reproduction sources?
« Reply #5 on: May 18, 2020, 08:21:09 PM »
Don't have any pictures for a 69 and other years would differ. Not allot of examples out there and with the fender off
Need to find some for one of my cars. Just installed one of the other plugs in the hole to fill it for the moment
Offline ninedrvr
Shelby Antenna Relocation
« Reply #6 on: July 29, 2021, 09:24:28 PM »
With the relocation of the antenna to the trunk, what did A.O.Smith do with the 3 holes left over from a mustang type antenna installation? The big hole is the same size as the other hole in the "A" pillar, so another body plug will do there. The question really is what happened to the 2 other antenna lead retainer holes? Any pictures of an original would be appreciated.
Re: Shelby Antenna Relocation
« Reply #7 on: July 30, 2021, 02:46:16 PM »
I believe that antennas were installed at the dealership so no fender holes from the factory, even for a Shelby.
Offline ninedrvr
« Reply #8 on: July 30, 2021, 10:18:44 PM »
Did you find any plugs for this?
« Reply #9 on: July 30, 2021, 11:01:09 PM »
I figured that you already had your answers from here .   https://www.concoursmustang.com/forum/index.php?topic=22532.msg156244;topicseen#msg156244
Offline ninedrvr
« Reply #10 on: July 31, 2021, 12:42:23 PM »
I forgot about that thread when I started this one. I remembered the thread and reread it but I'm still not sure what to put in the smaller holes.
« Reply #11 on: August 01, 2021, 09:06:09 PM »
Merged the two threads
As mentioned above there would have been no antenna installation done at Dearborn
 Picture collection is always increasing so here is a picture of the passenger side A pillar between the door hinge as requested. On both of the hinges the forward bolt has been removed
« Last Edit: August 02, 2021, 05:51:54 PM by J_Speegle »
Offline ninedrvr
« Reply #12 on: August 02, 2021, 03:07:20 PM »
Wow!! That picture is great! Answers more than one question.
Thanks Jeff
« Reply #13 on: August 02, 2021, 05:51:23 PM »
Thanks Jeff
Thanks glad it helped and that I was able to get a shot of this challenging area of the car.
