Author Topic: Correct Alternator  (Read 911 times)
Offline ddonzella
Correct Alternator
« on: May 18, 2020, 01:46:48 PM »
Hi,
Shelby GT350 June 12, 1969 Dearborn, production number 3000.
My original Build Sheet lists 4B under alternator option. it's a non a/c car. Can anyone decode this for me? Additionally would I be correct in surmising that the alternator ID should be metal stamped C9Z-----and should be matted with a blue with silver lettered voltage regulator?
Thank You!
Re: Correct Alternator
« Reply #1 on: May 18, 2020, 01:53:44 PM »
Hi,
Thank You!
Study this for your answer. This is correct information. https://www.deadnutson.com/1965-1971-ford-autolite-alternators/  . The typical regulator for your application is the blue cover "C8AF " silver letter regulator. Not the yellow letter "C8TF".
Offline ddonzella
« Reply #2 on: May 18, 2020, 02:26:59 PM »
Thanks Bob,
He indicates that my mid year 69 would have a C6AF coded alternator. 1966 casting and not 1969?
Are you able to decode the 4A on my build sheet to be sure?
Thanks, I'm trying to learn.
« Reply #3 on: May 18, 2020, 07:33:29 PM »
Thanks Bob,
Some 69 BOSS 302 got a C6AF marked alternator too .  ;) I agree with Jack's website. The engineering number is metal stamped in this later 69 case.
Offline ddonzella
« Reply #4 on: May 18, 2020, 09:15:10 PM »
Thank You Guys!
