Author Topic: Spring perch bushings  (Read 543 times)
Offline evantugby
« on: May 18, 2020, 01:33:05 PM »
Gents,
Restoring my suspension and I noticed my new spring perch bushings don’t appear to be the correct appearance.  Can you verify and if they are not where is a concours-correct bushing?
Re: Spring perch bushings
« Reply #1 on: May 18, 2020, 01:47:35 PM »
Gents,
They need to have a bare steel appearance the same as the spring perch.There are a number of different ways to make that happen . This is how I do it. I dunk them in a bath of Muriatic acid for about two minutes so that the zinc plating disappears.Use caution!!Use safety glasses and rubber gloves.  Rinse in water then dry with towel . After dry teat with rust inhibitor. If you blow dry they will flash rust.This is just the way I do it .Others may do it differently.
Offline evantugby
« Reply #2 on: May 19, 2020, 01:15:43 PM »
Bob,
My thought is this:  I prefer to keep original parts so it is much of a thoroughbred as possible.  With that being said, Since I can’t find a concours-correct bushing for the spring perches and since it is not necessary to replace the bushing, should I keep the original bushing in place?  Would like to hear what people think.
Thanks all!
« Reply #3 on: May 19, 2020, 05:44:05 PM »
Those are known to squawk and make noises, even driving across a parking lot (or being pushed if a "never started" Thoroughbred).  I would change them.
