Author Topic: 1967 GT 350 (Early 10/66) Body Style Stamped in Rocker Panels  (Read 1023 times)
Offline cmfuser01
Would the body style, i.e. 63 A(?), typically be stamped on the bottom side of both rocker panels on these things? Were there any other stampings on the rocker panels visible on a finished car?
Thanks.
Re: 1967 GT 350 (Early 10/66) Body Style Stamped in Rocker Panels
« Reply #1 on: May 15, 2020, 07:44:59 PM »
Well sort of. Since the coupes and fastbacks use the same rocker panels they are stamped (in a very big thin stamp) 65
As long as there is not a bunch of filler, thick primer then like originally the date stamp would be visible also
« Reply #2 on: May 15, 2020, 07:47:45 PM »
+1.  You’ll see a 63 in the trunk under the panel between the back window and deck lid.
Offline cmfuser01
« Reply #3 on: May 15, 2020, 07:54:51 PM »
So both the coupes and fastbacks have a 65 stamp?
« Reply #4 on: May 15, 2020, 08:09:29 PM »
That is what the example (top picture) is showing
Its from an original late 67 GT350
Had a similar question from a fastback owner (different year) a couple days ago
« Last Edit: May 15, 2020, 08:12:34 PM by J_Speegle »
Offline cmfuser01
« Reply #5 on: May 15, 2020, 08:57:33 PM »
I'll look for that thanks!
Offline cmfuser01
« Reply #6 on: May 15, 2020, 09:02:29 PM »
Thanks gents - another mystery (to me) solved.
I figure it's not Shelby specific but wanted to make sure the proper context was considered.
