Author Topic: AMK Brake Caliper Hardware Kit for 68-73 - F3698  (Read 1512 times)
Offline Aussie_Boss302
« on: May 14, 2020, 03:46:49 PM »
Has anyone used the AMK Caliper Kit and does the caliper brackets have the galvanized plating similar to the factory pieces?
« Last Edit: June 30, 2020, 09:41:18 PM by J_Speegle »
Offline 69BOSS302
Re: AMK Brake Caliper Hardware Kit for 68-73 - F3698
« Reply #1 on: June 30, 2020, 08:33:10 PM »
Roy, I have just bought one. It is at the shop, but I will take a picture tomorrow. It looked very original if memory serves, but lets confirm with a picture.
Philip
« Last Edit: June 30, 2020, 09:41:24 PM by J_Speegle »
69 BOSS 302
9F02G198123
May 23, 1969 - Dearborn
« Reply #2 on: July 02, 2020, 10:32:11 PM »
Thanks Phillip
Offline 69bossnut
    • DSD Restorations LLC
« Reply #3 on: July 09, 2020, 01:59:38 AM »
Roy,
The finish is not spangled galvanized like the originals. They are just zinc plated like about all things today.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
« Reply #4 on: July 09, 2020, 12:16:24 PM »
You may want to consider the faux finish galvanizing process Jeff S. came up with posted in the library section. Using the bright zinc as a base to start from should help make for a proper convincing look. On a small part like the covers the finish can be made to look almost indistinguishable from the genuine finish.
« Reply #5 on: July 09, 2020, 12:45:54 PM »
Thank you all... i did find a set of NOS brake caliper shields
